I keep hearing about an intermediate shaft... what is this?
P.S. I don't have a samurai yet or I would just go look. (I do a LOT of research before I buy stuff, I try to learn as much as possible.)
on samurais the transfer case is divorced from the transmission and the transfer case actually sits around a foot behind the output of the transmission. the intermediate shaft is a drive shaft that connects and transfers power from the transmission to the transfer case. looks just like a driveshaft with u joints but is very short.
Oh o.k. cool, so I guess that puts the transfer case closer to the center of the vehicle then... The front and rear driveshafts aren't by chance the same length, are they?
yup,
but the good part is that if you lift the vehicle and have to lengthen the driveshafts, you can actually shorten the front a little and put it in the rear. most shaft shops charge more to lengthen them than to shorten them.
