1 - 1 of 1 Posts
Hay guys, I have had trouble finding the bad vibration on my SPOA Samurai when I am in 4 wheel drive. It sounds like the u-joint is bad. I have changed the driveline, transfer case and the front 3rd member and it still does it. he only thing left is the angle of the front differential. It goes straight to the transfer case with no angle but there is angle at the transfer case. Should the angles at both ends of the driveline be about the same. I am sure one of you guys know
sturgeon95
1 - 1 of 1 Posts
