07sx4
Today 05:43 AM - permalink
07sx4
ok so i know this has been posted on here before but i would like some help. my question is how hard is it to remove the rear drive shaft on 07 sx4 awd? what are the steps, and anything i need to watch out for. the vehicle is an automatic. i have worn out u joint and need to replace the driveshaft. thank you for all and any input. and torque specs for the drive shaft bolts. thanks again.
I suppose this is about the center drive shaft, not the half shafts to the wheels.
So...try this (from the 2007 shop manual)
www.avigex.ca/sx4/driveshaft.pdf
NOtice this shaft is said to require total replacement but several have been able to have the u-joints replaced. There is a thread somewhere about this....ahh..yeah found it..but it relates to a place in Canada....I do not know where you live...????? They were talking of Rockford u-joints that have been used for replacement http://rockforddriveline.com/replacem.htm though I do not see Suzuki in their list....but it is said their instruction sheet gives useful details even if SUk not listed.
try this also https://www.powertrainindustries.com/about.htm
thanks for the info lmp, i'm sure it'll be very useful when i do it. and yes it is the center shaft. thanks again.
Discussion Starter · #5 ·
drive shaft install
ok so ive got my drive shaft out and ordered one from a salvage yard,be here within the week. now my question is,is installing one just a bolt on application or does it have to be oriented in a certain way?? thanks for any input.
