Anyone know what the drive cycle is for a 2006 Suzuki Verona - or what it will take to get the EVAP and Catalyst monitors to reset?
yes, if there is pending code and if there is a check engine light on then it wont finish the whole cycle until the problem is resolved. but if you have no pending codes and you have no check engine light that is on, then you will have to turn on the car, let it idle for 10 minutes, then drive in a high way for approximatly 60 to 100 km. then turn off the car for another 10 to 20 minutes turn it on again drive it for a short distance and it should finish the whole cycle, however if there is a problem in the system like the evap then it will stay flashing and will not reset, its the last one that get tested in the cycle this is why you need to drive the car for a while. so i would suggest you do that if you like highway drives or crusing around for few hrs, i hope i helped and i hope things work out for ya
