Is anyone or has anyone had to adjust the door sensor. Our dash light comes on when we're driving and all of the doors are closed tightly
Might be a fues.. check owners manual and see if there is a specific fuse for it.. if not I would take it into the dealer as it would probably be a bad sensor.
I'm guessing either a bad sensor or else one of the switches needs "toyed with". With the car idling, open each door one at a time and see if you can push the "button" that depresses when the door is closed and see if that tells you which door sensor is causing the problem.
A blown fuse would be more likely to stop something from working at all, no?
