I tried looking for the drain and fill plug in the main Transmission body but i didnt find them. Instead they were located in the Transfer case. So i drained and the fluid exactly 1.5 Liters came out. Filled it up again until fluid started to overflow (thats the rule right?) BUT it took 3 liters? I read somewhere that Tranny and Xfer case dont share the same and that theyre about 1.3 Lit EACH! I am not firing up my Carry until one expert tells me i did the right thing.
Greetings! You don't know what you are doing and I don't ether! LOL
NOT an expert, but book says as follows:
Transmission oil Change 2 years / 20oooKM Gear oil #90, Suzuki GL-4.
4WD part time 2.6L.
Differential 2 years / 20000KM 75W-80 (GL-5), 4 WD PT, front 0.7L, rear0.7L
IF I get my scanner working tomorrow, I will post about the plugs, and other junk.
Please stop doing until you got the specifications!
What U R supposed to do is wait, wait, for correct info!
Please tell me the cooling fan does NOT run all the time?
So they appear to be over filled, with the wrong oil, and no room for expansion.
Who ever U been getting your info from, please don't do it again!!!!!!!!!!!!!
