I have a cooked 98 suzuki jimny motor and I'm looking to replace it with a 1.6 vitara engine, would it fit the engine punts within the jimny?
You can use a Vitara, Baleno or Grand Vitara engine. The easiest swap is the Grand Vitara 1.6. If you use the Vitara or Baleno engine then you will need to fit the Jimny sump and modify the pick up pipe. You need to use a gearbox adapter kit and one modified engine mount - the adapter kits that are sold for SJs fit. Use the Jimny manifolds and sensors but fit the 1.6 injectors.
