Is there a difference on these two year models? more specific on both auto, awd, because when i go to edmunds or kellybluebook they give different options, but do both have the same ground cleareance? gear ratio? audio controls on steering wheel? thanks in advance
The trim packages between 07 and 08 are very similar. The biggest change from 07 to 08 was the taller fifth gear. I think the only difference you would notice with the automatic transmission is the 07 fuel door has a spring operation (Push to open from the outside) vs. a lever inside the cabin to unlock the fuel door in the 08. There may be some other minor changes but that is all I have seen.
