1 - 9 of 9 Posts
just wanted to put together a list of the diff ratios for the ngv. if anyone knows different then let me know
there was a website i found a few years ago that had all the models new and old and which diff ratios but no idea where i found it, i think it was a uk site??
here is what i have found
1.6 manual - 4.625
1.9 manual - 3.585
2.0 manual - 4.111
2.0 auto - 5.125
2.4 manual - 3.727
2.4 auto - 5.125
2.7 manual - 3.583
2.7 auto - 4.3
3.2 auto - 4.3
Hi,
Great Info :)
I run a 1,9 ddis and would like to gear it Down a bit to compensate for my oversized tires.
Do you know if the housing and flanges are the same across the engine and transmission types, or is it not that easy?
Regards Jens
Hi,
Great Info :)
Regards Jens
I wonder if the 2.4 auto's diff would fit on the 3.2 auto? I would love to put even bigger tyres on my GV then :D
Pretty sure the are all the same its just the pinion and crown gears would be different. Get some part numbers from Suzuki of the housing for each model and compared
2007 Suzuki Grand Vitara JB420
Reviving this thread to inform that 4xfourart has a 5.85:1 ratio ring and pinion
Its 350 Euros which comes up to about the same price as a brand new OEM ring and pinion
Reactions: Mikebtte
Have to do the math and see what the RPM would be and how big a tire I would need to run in order for the gears to work.
As best as I can tell, 40 inches would give you almost the same as stock
1 - 9 of 9 Posts
