1 - 8 of 8 Posts
hello once again
i have come across another problem on my sierra i had a look underneath my plastic sill covers today and this is what i found
Has any had to deal with this im looking a covering it up with some thing but with what and how do i do it?
HELP PLEASE:eek:
rust!
Smokingrezel has described a common DIY cure - the best one in my opinion. Unfortunately, the plasma cutter and wire welder part kills that idea for most folks.
Samurai body parts are hard to find in the US, so you have to improvise.
A lot of folks take the bracket that holds the plastic rocker panels off with a grinder, remove the rust area, weld in new sheetmetal, seal the work then cover it with aftermarket or home-made rockrails. Another choice is to thoroughly clean out the rust,fill with insulating foam, sand smooth, then patch the surface with epoxy and maybe a piece of fiberglas. Top your work with rockrails to cut down on trail damage or to add some 'bling".
The only cure for the rear bumper is to get a new one. The chromed version may be hard to find. An even better solution would be to replace it completely with a tougher aftermarket one.
Here are a few links to OEM or replacement body parts:
SJ410 & SJ413 : Extremebends.com | Landcruiser Toyota Parts and EBI 4x4 Accessories
Showcars- All Your Suzuki Needs - Fiberglass & Steel
The above were found by selecting BODY as a search category at Ack's FAQ (see link in signature, below) and leaving the search word field blank. There is also a couple of other links in that search that might be helpful to you.
I hope that his helps!
There is a donor truck in my local pull-a-part that has good panels, I could use the sawzall and get for a decent price. Then all that would need to be done is the mig, a little bondo, and paint.
thanks for the advice i like the idea of the foam then fiberclass and rock sliders over that to protect it its a bummer i live in australia so ill go inquire at my local wreckers thanks any way
has anyone got any pictures on some ideas
thanks
thanks
You think you have it bad in Australia...
They stopped selling the SJ-413 in the US back in 1995.
I bet you'll find what you are looking for in the salvage yard.
here is a post that might give you an idea:
Repairing Door Sill Rot
thanks mate i have stared the process of cutting it ou and starting a again thank you for the help
1 - 8 of 8 Posts
