This link has a lot of good information on our cars. It gives you a place to start anyway. Suzuki And other small car builders use other engines from cars in production to keep cost down. I found that the 1997 Suzuki Esteem 1.6l engine and tranny came from the Toyota Tercel. So with that said you now have a aftermarket, A small. I believe the same thing is at work here. Daewoo used Holden engines in the past, So if you can get the part numbers for a part you should be able to match it to you car. I am waiting for a part numbers list for the 2005 Reno, After i get it i will go online to search for other cars with that same number and them check them to make sure they are the same part. If it turns out that Daewoo used parts from other cars that have an aftermarket, More performance parts should be found for our cars.Like i said this should work, But like anything in life i just have to get lucky.
GM Daewoo: Information From Answers.com
