Hello,
I have a 2013 AWD auto sx4 with about 115k miles. I pulled out of a gas station in manual mode, when shifting from 3rd to 4th the car acted like it went into neutral. After getting the car off the road I could not get it to move in any gear. After getting it towed home I ran a code scanner and got a U0101 and P0722 code. Any ideas, i'm a good ways from a Suzuki dealer.
Thanks!
It appears the code U0101 means the transmission control module has lost communication, but is also showing P0722 as there is no output speed signal. This communication is done via Can-Bus which is beyond my help level I'm afraid.
Welcome to the forum.
Thanks, this forum has been great help with previous Suzuki Aerio I owned. I was hoping it was just an easy change out of TCM or sensor vs. a whole transmission.
TCM has gone to sleep and not comm with PCM, check power and ground to TCM..
... Philip
That's what I was hoping. Bought the one day version service manual and did some troubleshooting. Tested all power to relay and TCM, had proper power and good grounds according to service manual.
