Located in Nashville, TN
Long story short:
Bought a few years ago from a guy who built it on Pirate4x4 (see the for sale thread here). Ran perfect before I was deployed, came back from deployment and can't get the engine to run perfect (I think the timing may be off, as I've checked the dry and wet compression, fuel pressure, and the ohms on the injectors... all of those are good). I was planning on rebuilding the dash with an aluminum panel, so the dash is apart right now as well.
$2,750 FIRM. Will deliver / ship for additional cost. I've got a trailer for sale as well that I can work into the deal if you need it.
Text or call for fastest response: four oh 4, sevon ate 7, eight 9 sevin for
Thing's I've done in the last 60 days:
Optima Yellow Top Battery, Fuel Filter, ECU, Cleaned Injectors, Spark Plugs
Additional Parts It'll Come With:
Another front axle
Lots of additional axle parts (carriers, axle shafts, etc)
XRC8 winch with synthetic line
Windshield
Misc. lighting
10 gallon plastic fuel cell
Spare driveshaft (needs to be lengthened), spare fuel pump, spare rotors and calipers
And more...
Specs:
-98" wheelbase, stretched about 6" front, 10" in rear
-39.5" bias iroks on 2.5" backspaced wheels. Two of the tires have a very slow leak.
Drivetrain:
1.6 16v EFI swapped from a great running Sidekick (twice HP of stock Samurai engine)
-New water pump
-GM alt swap
-Trail Gear high output P/S pump with tapped IFS box with hydro assist, larger ressy, and cooler
-6.5:1 geared transfer case with "slutty snatch" cradle (one of the best on the market)
-On 7-9-13 replaced clutch with stage 3 kit along with throwout bearing and pilot bearing
Toyota Axles: Solid front IFS rear
3 Linked front - 4 Linked rear. 5.29s, Aussie/Lockright
Front:
-2" .250 wall DOM links w/ 7/8 Ruff Stuff heims.
-2.0 16" Fox air shocks
-TG Diff Armor
-Entire front rebuilt January 2013, new seals and everything
-Aisin IFS hubs with Longfield chromo hub gears and TG Super Knuckle Stud Kit
-30 spline Longfield shafts
-1.5x6 hydro assist
-Six Shooter steering arms/knuckles with ARP studs
-Heim steering on tie rod and drag link, both 1.5 .250, with pitman arm double sheered
-Trunnion bearing eliminators
Rear:
-2" .250 DOM lowers
-1.5" .120 DOM uppers
-7/8 Ruff Stuff heims
-TG Diff Armor
-QA1 150lb coils
-Bilstein 5150 shocks
Other stuff:
-Electric Fan on switch
-Corbeau Baja SS seats with Crow 4 point harnesses
-Fully caged 1.5 .120 HREW
With a little engine love, new dash cover (or reinstall the old), fresh paint on the cage, and a new set of shoes, this Sammy will be like new and will keep up with the best of them.
