1 - 8 of 8 Posts
looking for info on cruise control install into an 05 forenza wagon. I have a set of dash switches and access to a tech 2 for programming.
I need to know if the column is prewired .
What other parts I may need.
How to dissable airbag to work on column.
thanks
the steering column is not pre wired nor is the ecm
take off the air box on the engine and remove the cover on the ecm and wire into slot 45. 48 is far left and marked. I think it goes green yellow purple 45 blue .
you must wire 45 which is the slot for cruise to your module.
and proir to anything find techs that KNOW DRIVE BY-WIRE CRUISE no one here knows anything and what an f'ing headache
if you go oem you might have an easier time due to some suspicion I have regarding the GM/DELPHI connection and the need to possibly by recoded or programed. good luck
I installed mine one to two weeks ago and have only been checking connections to see why it wont work I beleive the ecm doesn't know to look for it and cant get stealership to even go in to try and program it. I AM STARTING TO HATE THESE SUZUKI TECHS ALL I GET IS NO AND NEVER ANY HELP.
go to the cruise control store they will help your search come to an end. 06 is diff than 05 but that will mean youll just save money on a kit if not drive by wire stay away from accelerator pedal cable install kits, dangerous.
1 - 8 of 8 Posts
