I had the timing belt fail (less than two years old- Ever Green brand). After opening up the cover, I can find no apparent reason for the failure...other than it being a crappy belt. When the belt broke, the engine died, so I'm hoping there was not valve to piston contact...it happened while coasting at very low speed. Is there an easy way to tell if there was damage without removing the head?
The FSM states to not turn the cam or crank independently of each other, however I need to align the "E" Dot on the cam gear and the Dot on the crank with the "arrow"...so I need to turn the gears independently of each other. Is this a potential problem?
A forum community dedicated to Suzuki owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, reviews, maintenance, and more!
