I need a help to check the coolant temperature sensor on 2007 Suzuki Forenza.
As this car had some issue involving coolant hose busted and engine very hot,I want to make sure that this sensor is working properly.
Also I need to know where is it located in the engine compartment.
If this sensor is bad, will the scanner show any code or not?
My check engine is on but the code 0113 is related to air temperature.
Thanks for your help.
Coolant sensor is in the driver side of the head, on the side.... near the coilpacks. Look for a 2 wire sensor / plug.
