I have a coolant leak on the back side (firewall side) of the upper part of the engine it's bone stock I'm trying to find it. Kind of a bad leak constant drip if the Sammy's running.
Any ideas would be helpful
I'll look and see, but I think the heaters lines are connected to the firewall. Thank you for your advice and ill double check.
The heater has to connect to the engine doesn't it? they still connect to the pipes running along the engine and then go thru the firewall to the heater, common leak point.
Don't forget, the original car is heated from circulated coolant off the intake manifold......just above the starter. Check those lines while you're at it.
