What are you putting it in? --- Year, model... number of doors... things like that.
If it has airbags (generally '96 and up), I suspect that it would -not- be a good idea.
'89 (2 door) into anything up to a '95 2 door, I don't see a problem. It does take a different snap-in insert under the column on the dash. ('92 to '95)
As I have a '94 4 door with tilt, and it LOOKS the same, it is likely into a four door would work also.
That said....
I don't move any of my tilt columns. I doubt you will see any real benefit that would justify the work needed. (Just say'n.)
