1 - 14 of 14 Posts
1991 Geo Tracker/8V/Manual & 1996 Geo Tracker/16V/Auto
Is it 132 in. lbs., 162 in. lbs., or 108 in. lbs.?
I’m seeing a lot of different numbers.
I adjusted all my valves perfectly, fired it up and had a few seconds of pure quietness, then loud. Pulled the cover again and they all loosened up. I don’t think I’m tightening the jamb nut enough (scared to strip it), and just want to hit it with the torque wrench.
ANY of those values will successfully tighten / lock in valve lash adjustment. You have either some other mechanical issue to contend with OR your Torque Wrench is suspect. :(
Discussion Starter · #5 ·
I haven’t been torquing them. Just snugging them with a wrench. I have a tendency to over tighten stuff when I comes down to inch pounds. So I’ve been worried about stripping them out.
Let’s chalk it up to the loose nut behind the wrench for now. If I keep having problems I’ll blame something else. 😂
Inch-Pounds to Foot-PoundsConverter
You gave us the impression that you were torquing them, but weren't sure to which of several specs to shoot for, is why I responded as I did.
Pick the advertised mid-range (132) and go for it!
Discussion Starter · #7 ·
People actually need that converter? It’s divide by 12 or multiply by 12.
I had a couple come loose. Pretty sure it happened while tightening down the jamb nut.
Hmmm…..I would find it somewhat unusual that any 8v engine would give you ‘pure quietness’ with regard to the valves.…lol
Reactions: Flesh Eater
Discussion Starter · #9 ·
Thanks for the confirmation! Hahahaha!
This is my first Suzuki, so I’m learning all about it. Not sure how a good one “should” sound. Mine went from crap to awesome, and I think I’m trying to make her too perfect.
She runs so good now. I love this even more!!!
Next is to get my 96’ red Tracker engine swapped and on the road. 😁
Here she is after a rip and second compression test confirmation. Got the winch and bumper on as well. All ready for some serious snow fun!
Tire Wheel Automotive parking light Vehicle Car
sweet!
i was considerign a 6000lbs winch... will be interesting to understand how a 5000 does on yours.... give it a try when you are out there :)
what brand is the winch?
with those tires, do you have lower ratio diffs or transfer gears installed?
Discussion Starter · #11 ·
sweet!
5,500lbs. winch is way oversized for this little guy. 😂
It’s a Badlands Harbor Freight junk winch. I got it with a parts Sidekick I bought. Came with the bumper and winch, so I fabbed it up to the Geo.
Just running the stock 5.13’s. I do have plans to add the 3:1 Trail Savage transfer case gears and twin sticks. It runs so much better with 4 cylinders than 3!
gee... dont even want to ask whats the top speed in 5th with those tires and stock gearing.....
1 - 14 of 14 Posts
