I have read that you need to pull F! before doing a compression test. Where is F1 on a 93 sidekick ? 1.6l 16v
Thank you
Lon
Thank you
Lon
It's actually FI for Fuel Injection - it's so you don't dump more fuel into the cylinders when doing the test. If you know where the fuses are by the drivers side kick panel - look there.
I can't be sure its in the same location in your car as mine, but in my car it is the bottom row of fuses (under the dash) the last fuse on the right - 15a
