Hi everyone,
I have a 1986 Suzuki Samurai that is running rough with low power. I did a compression test on all four cylinders and the results were
Cylinder results
#1 30 lbs
#2 40 lbs
#3 150 lbs
#4 150 lbs
I also put air to the #1 cylinder when it was at Top Dead Center and had air escaping out the exhaust. I also pulled the #2 sparkplug and had air coming out that hole from the air I was putting in #1.
Do you think I have a blown head gasket or exhaust valve issues?
Thanks so much..........eddie
Doesn't Matter Which One....either Way You Have To Pull The Head And Replace The Head Gasket...while The Head Is Off Have The Valves Checked...right?
