1 - 9 of 9 Posts
Like I said I have a COMPLETE power steering conversion kit from an 8V engine for all of you non-P/S folks out there. This kit will work as far as I know on any '89 through '95 Tracker or Sidekick. What makes this kit complete is that it includes not only the P/S gearbox, pump, pump bracket, resevoir, both hoses (pressure and return), steering shaft, but also the correct crank pulley. You see, I just learned this myself this last weekend. If you try using a non-power steering crank pulley (which is smaller in diameter) you will not get enough pressure and volume of fluid to properly operate your steering. Although the crank pulley on the non-P/S engines is a double pulley that can run 2 belts, it won't spin the pump at the proper speed. The difference is night and day. I know because I just did this mod this past weekend. If you don't have P/S then you don't know what you're missing! Anyway, I'll take $250 shipped to the lower 48 states. You can PM or respond to me here if you're interested.
Discussion Starter #2
I've still got this available if anyone's interested. If not, I'll probably put it up on ebay or craigslist. Thanks.
I'm told that you would have to get a different mounting bracket for the power steering pump but otherwise it will work on the Samurais.
I'll take $200 plus shipping whatever that turns out to be. I'd have to know that your committed to that before I box it up and go running around to get shipping quotes. I'll check USPS and UPS for the best deal. I'll do what I can to get you the best deal. Let me know. Thanks.
great just let me know you want to handle it? and just to clarifie it, it is a complete kit? do you have a paypal account?
thanks Kurt
Yes it is a complete kit for a TRACKER or SIDEKICK. Like I said before you may have to get a different pump mounting bracket for a Samurai, but I'm not sure about that. This will fit on a 1.6L 8V engine because that's what it came off of. My PayPal is [email protected]. I will get it packaged up today and get you the best rate on shipping that I can but I'll need your shipping adress info before I can do any of this. If you'd like you can email it to me (my email is the same as my PayPal listed above). Thanks, Charles
1 - 9 of 9 Posts
