As it states in the title. I removed the waterpump after replacing 2 thermostats and the . Both thermostats are opening at about 185 or so on the kitchen stove with a thermometer. I replaced all the antifreeze and did the burp of the cooling system with the large funnel until all bubbles were gone. Let the car sit and idle in my garage for 30 minutes, then revved the engine to 2200 rpms for 5 minutes or so and the vehicle stayed cool. Plenty of heat through the vents. I drive it to put it under load and it overheats in 5-6 minutes, then the gauge comes down pretty quickly, so I drive it a little more. It gets HOT and stays hot. I let it cool down a little and drive home. Pulled the waterpump and am now inspecting it. The fins move as typical inside the waterpump as I spin the pulley. I was hoping that the spline that holds the fins would've been severed, so I would definitely know it is bad, but it makes an ever so slight noise when I spin it, but certainly not the fried bearing sound. I hate to replace the waterpump and still have the same issue. Car has 85k. No antifreeze in the oil. I took a couple pix of the inside of the waterpump.
Any ideas would be awesome!!
