First - there are two coil packs in use with the J18 engines - a 2 wire coil pack and a 3 wire - you need to know which you have - look at the plug where the wire harness connects - how many pins do you see?
Second - the coil packs can be disassembled - there is the coil itself and a rubber lance or boot beneath it which can be detached - they are sold separately.
If you can't find what you need, Suzuki Australia might be a good place to check, however both should be available through SouthWest Suzuki in Texas, you car would be called a Suzuki Esteem with the 1.8 engine in the US.
I assume that's a Japanese Domestic Model (JDM) it would usually be called a Baleno in NZ and Auz.
