Does anybody know if I could use a GM codereader for a Suzuki Sidekick. The Chevy Tracker has a Suzuki Sidekick engine in it so i figure they both would probably work with gm code readers right? Any help would be appreciated.
The 92 1.6s use OBDI and do not use code readers. To check the codes you have to use a jumper wire on a special connector underneith the hood. When you jump it the engine waring light will flash. The sequence of the flashes are the codes. I can give more details on how to do this if your intrested, and I also have the code descriptions.
