Hi All I am currently replacing my clutch, pressure plate, Throw out bearing and slave in my 04 Forenza and I came across another problem. I will not be able to bleed the clutch if I continued because the bleeder was rusted in sleeve. So I decided to try and free it up before re-installing it into the transmission.. well..
I broke the little block that connects the slave to the hard line...
here this part I broke.. I broke 2 of them because one came on the used transmission I bought as well... they are plastic with brass sleeves and they just would not budge after letting sit with PBblaster even. One just keeps spinning with sleeve and other cracked and broke.
Circled in red is the part I am having problems with, I need help asap please.
Here you can see what it looked like before I broke it.
here you can see what it looks like after I broke it...
(just keeps spinning)
Can i buy a replacement or should I check a junk yard?
I did find this but I am not even sure if it is what I need...
Please help I have everything else ready and installed and waiting to go back in my car. I have been without it for 2 weeks now and keep using my wifes SUV for work and it just plain stinks. I need me lil beater back...
let me know if you know a part number for that part of where i can get one?
I am all set now, the new Part costs 65 at dealer but I decided to just make my own replacement part using a junction block. Works great and is metal and not plastic so should last longer. Lol thanks anyway people
HI I drive 20006 SUZUKI FORENZA and im trying to figure out where I can get or order part number 15 in your top pic and not the hose part the Black plastic part that goes on top of the slave cylinder line (#12). mine when I put the lil copper pin back in when its on (#12) its loose as a gooes and I think that's why my clutch pedals to the floor....
hi the black part with the nipple on it is the clutch bleeder valve. i believe thats what your looking for. the part sticking out of the transmission is the Slave Actuator Cylinder. i think you might have to get it from a dealer. let us know how you make out
It looks exactly like the 3 way T coupling I have on my brakes on my toy car, available from any reputable brake shop, you may have to get them to make the pipe up as well depending on threads, but its cheaper than genuine.
I went to auto store and made one up using brake line and flange tool and a little block adapter. still in my car to date. BTW my car is seriously falling apart now. prolly on its last winter. has 130k and big rust holes in rocker panels. lol
probably needs another clutch the way I drive.
still for 11k brand new it has lasted me good since 2004. did all work myself on this heep..
can't wait to get something else. I dont even have my jeep anymore. I got a wrx but then the motor had a rod bearing issue and I am still rebuilding that. hope the suzuki can hold out this winter. haha
I am just going to drive it. The motor will have 0miles on it sort of so I'm gonna see how long I can make it last. Haha. But as for buying another zook they stopped selling in USA
Hey everyone,
My girlfriend was driving my Forenza the other day, got not even a mile down the road, and the car stalled on her. She said she heard a hiss like something released pressure, then all the lights came on on the dash and the car died. She swears there was no grinding, jarring...
Help plleeaase! Does anyone know of any vehicles this switch may be compatible with? Its going to take over a week to order one in and can’t be without my vehicle that long. I’ve figured out how to run it without but am not totally comfortable driving it like that 😂
We have a 2008 Suzuki Forenza and the hood release cable is stretched and the hood latch seems to be sticking as well! We ordered parts for it but they aren’t available in the US and we received and email stating they would take 8-10 weeks! We have some things to repair and need to get the hood...
My daughter's 07 Reno, 2.0L GM engine, automatic trans, cut off going down the road, got it towed and found the battery was bad, replaced the battery and the starter would spin, but not engage the flywheel. My son replaced the starter, and it has the same problem, the starter spins but not...
A forum community dedicated to Suzuki owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, reviews, maintenance, and more!
