I've got a 1988 Sami 1.3 8 valve with 5 speed trans. I replaced the clutch after an oil leak soaked the other clutch. I have adjusted the clutch but when the peddle gets almost to the firewall it has a feeling like breaking over. When starting off the clutch really grabs at that point. The clutch does not disengage till that point is reached. Have I not reached the proper adjustment point on this clutch? Other clutch did not have this feeling.
GIZMO
ive got a exedy heavy duty clutch in mine and it is either engaged or disengaged there is no riding the clutch a little to take off just have to rev it and drop the clutch
Got it.......Thanks for the help. Had to crank down on the clutch cable more with this new clutch.
GIZMO
