I had a problem with my clutch the other day. I checked adjustment and it seemed fine. It seemed to come out of it. The problem was it seemed like it didnt disengage. I could not shift. Then I tried starting it in gear, with the clutch pressed to the floor, and it was still engaged. and wanted to propel forward. I played with it, and had a friend push clutch in as I watched the lever from the bell housing. There is plenty of movment, and I have very little play in the lever like it suppose to have. Then it seemed to come out of it again. I drove the tracker 25 miles, with not any problems. Today, I went to the store, and it started acting up again. I could not shift to the next gear. I went into a parking lot, and again, I could not shift while running, and even with the clutch in, and starting it in gear it wanted to propel forward. I was lucky enough where I could start it in gear, and with the clutch in, it slipped enough to drive it home, but, hard to shift into next gear, up or down. I know I want to eventually get the stop welded back on the clutch pedal, as, the clutch is adjusted very high, but, the adjustments seem fine. What is going on that it will not release when there seems to be plenty of movement? Anybody run into this problem? Thanks for any help.
