hi..replacing my clutch on my 88 sammy..which way dose the hub on the disc go,trans side with the flat side to fly wheel ? thx
Thx for the welcome!..and drawing..but what i need to know is which way the disc goes to the fly wheel..there is a flat side on the disc(which i assume goes to fly wheel) and on the other side kind of a hub(trans side ??) directions arent very clear with clutch purchase
Your correct, diagram shows this :p
If you look at the diagram (or drawing), you will see that it answers your question, the "hub" faces the transmission.
I believe if you flip it you'll find that the hub will hit the flywheel before the friction lining makes contact.
