The VIN cross references to the cable below. It's more accurate to check against the registration number so if you have an UK reg please.Vin is TSMMHY81S00172965
I beg to differ - that part number came from the same tool that Suzuki themselves use to order the parts, it doesn't get more accurate than that - if, for some reason a part is changed during the production run, let's say they switched suppliers, that tool will tell you the "break point", VINs before this number use part A, after use part BIt's more accurate to check against the registration number so if you have an UK reg please.
In your own words " see what UK suppliers come up". And I did just that. You obviously have no clue as to how the UK aftermarket works and if you step into any dealer parts department (including Suzuki) or any parts supplier - the first question asked will be the vehicle registration number since this is the easiest and most accurate way of finding the correct part.I beg to differ - that part number came from the same tool that Suzuki themselves use to order the parts, it doesn't get more accurate than that - if, for some reason a part is changed during the production run, let's say they switched suppliers, that tool will tell you the "break point", VINs before this number use part A, after use part B
The tool pulls information from an "as built" database of the vehicles and contains quite a bit of detail, engine number, transmission number, all the various options, right down to things like glass color - as an example when that particular Ignis left the factory (in Hungary) it was blue (Z7B).
What I did find interesting, was the VIN came back as an RM413 with a 1.5 liter engine and not an RM415 which is what I would have expected - the RM is a model code, the 4 defines the number of cylinders, and the 13 or 15 would usually define the engine size.
This is an easy cable to find in the UK. See link below to order online or there's many on Ebay (pick one that's posted from the UK) - just search 23710-86G40. Your local car parts shop could also order it for you. Your Suzuki dealer parts department could get one by the next day but far more expensive than the other sources outlined above.Help ! Im looking for a clutch cable for a ignis vvt 4wd 05 plate, can't find one, im a carer and need it for work, its a 1.5
Suzuki lists the 23710-86G40 as fitting LEFT HAND DRIVE vehicles, the 86G60 part is listed as RIGHT HAND DRIVE - the transmission is on the left, the RHD clutch cable is, I believe, longer.
110539[/ATTACH]
You're free to accept whatever information you feel is valid, from whatever source you choose, me, I prefer to get it from the "horse's mouth"
Whats the attachment supposed to be?Suzuki lists the 23710-86G40 as fitting LEFT HAND DRIVE vehicles, the 86G60 part is listed as RIGHT HAND DRIVE - the transmission is on the left, the RHD clutch cable is, I believe, longer.
I don't know why it's doing that, but you can try clicking on the attachment itself - its a "clip" from the dealer tool, showing the VIN number reported as an RM413 rather than the expected RM415, as I mentioned earlier, I would have expected it to comeback as an RM415, but the tool reports it as an RM413, even though it shows the 1.5 liter engine.Whats the attachment supposed to be?
Please can you share the tool like the dealer uses or give the link. Would be very handy to look up part numbers.I don't know why it's doing that, but you can try clicking on the attachment itself - its a "clip" from the dealer tool, showing the VIN number reported as an RM413 rather than the expected RM415, as I mentioned earlier, I would have expected it to comeback as an RM415, but the tool reports it as an RM413, even though it shows the 1.5 liter engine.
How significant is this? I don't know. How did it happen? I don't know. Does it mean that this vehicle is actually an RM413 that was fitted with an M15 engine at the factory? Maybe, I really don't know. Does this mean that there could be problems if the parts between an RM413 and an RM415 are different? Maybe, I really don't know.
To me, it's something that I found peculiar, I've never seen it before, and I mentioned it.
Possibly a shared part suitable for both and the human entering the data didn't really care, but don't quote me on that.I don't know why it's doing that
I was referring to the forum not posting the attachment as it should.
