have another question. on dry ground in 4 wheel drive if you trurn real sharp right or left you het a clicking noise from the front end. is this normal?everything seems to work great
I don't know anything about these little trucks since I'm a newbie, too, but every front wheel drive car I've owned with those symptoms usually meant a CV joint. So I'm guessing if you had it in 4WD and heard it in the front, maybe it's the same thing? But I'm sure Ack or some other knowledgeable person will tell you a more definitive answer.
