Hi all, hope you can help. I have a 03 Suzuki Wagon R+ 1.3. A while ago the battery died, recharged drove again for a day and died again. This happened for a couple of days while I was waiting for alternator to arrive, changed the alternator and all working for a while but died again, replaced the battery, worked for a while then died again, done a test on the battery using a multimeter and found that the battery wasn't charging, replaced the earth lead from the battery and tried the test again and still the same. I tried an OBD test but came up with no codes as the battery had been removed so everything had been reset.
Any advice on what to check next would be appreciated.
I am having a related problem. I have diagnosed a faulty alternator and I am trying to remove it. The workshop manual stated that the alternator should be removed from below but it gets stuck between other parts which ever way I turn it. How did you remove yours?
Is there any update to this having the same problem and its doing my nut in, new alternator new battery all earth points checked but yet battery not charging also nick best way to get the alternator put is actully through the top remove air vents and all brackets holding alternator point the wheel towards u and wiggle about and will come out
