hi, everyone. this will be my 2nd post. as ive said before, im planning to make visual upgrades of my 1999 Grand Vitara 2.0L. Im interested in changing my 16" rim and tires. but this is all i know about my rims, it is 16". would any 5-bolt rims fit with my ride? what are the measurements or specifications of rims and tires would i get? any suggested brand/design? lastly, would the rims of a Honda CRV 2000 fit my Grand Vitara's? thanks a lot!
Far as I know they would not plus I though they were 15"on the Honda, wheel width is 6" on the Suzuli, best look on one of the 4x4 assory sites you see on the right here. <_<
You should check out BigWheels.net- great replacement wheels at a great price. Best part is that you don't have to worry about the bolt patterns or getting the right offset, they do all the work for you. Just type in the make of the car and they'll walk you through the rest. But, if you must know the exact specs:
Bolt Pattern: 5x139.7 (5x5.5)
Offset Range: 0 to 20
Wheel Size Range: 16x6.5 to 20x8.5
OEM Tire Size (Front): 235/60-16 (235x688 mm)
Max Tire Dimensions: 255x721.0
Good luck. :thumbsup:
