The drivers door is not responding to the central locking remote key. The other doors work very well. Does anyone have advice as to the problem.
The problem will most likely be the lock actuator in the door, or the wiring connected to it.
When you press the remote to open the door does the little notch on the top of the door move atall ??. If so then it sounds like the electrolytic capacitor is dying in the actuator itself. If you are tech enough you could find a replacement capacitor on ebay or amazon for probs around about a £1/$1. The trouble is you would have to work out what current you need by reading the colours that are around the capacitor itself to know which one to buy.
