Does anybody know how to sort the idle speed on a carry van.its as though the choke is permanently on.
what year? model? engine type?
carbed or EFI?
Hi there. The first thing you want to look at is the idle air control vavle. It's under the carb lookup iac vavle. When on idle it let s air in with the plate being closed. Thay get blockt. Before removing see if some spray clean helps. If u remove let me know I'll send u more info.
all so check your Pcv valve it's the pipe.on the right coming out too of cr anck it's a little valve pop is out give it a good clean.
