1 - 12 of 12 Posts
Discussion Starter #2
guys,
ive set mine to 2 1/2 turns and RPM should be not more than 900RPM - you should be able to determine by listening on the motor if you dont have the tool.
kinda answering my own question :D
guys,
Sir pascal,
Would it increase the fuel consumption if I make it 3.5 turns?
Otherwise, if I make it only 2 turns, would my fuel consumption decrease?
The apparent "real" way to tune the carburator, as it is a fixed jet carby is to
1. once warm, increase the idle setting to slightly higher than idle
2. wind in the mixture screw ( lean the mixture ) untill it begins to stutter and jump around
3. then richen the mixture count how many turns it takes before the engine starts to "hunt" ,
4. divide the counted turns into 2 and then lean the mixture to that number
for example:
my car was leaned out and began to stutter and miss, i then richened the mixture by 5 turns before the engine started to hunt, since it took 5 turns out, i then need to wind the mixture 2.5 turns back in from it hunting
and, if you have a problem like i did, i could take the mixture screw right out, and it would still run ok.. the idle is too high, bring it down a bit,
if you want a more accurate mixture, bring the engine at its new setting, back to idle and repeat the process at idle speed.
this setting did me well on my f10a engine, i dunno what everyone else's would be like
I hope some body can help me on this.
My cab is an F6A 3 cylinder/12 valve, carbureted, rear wheel drive only, with no aircon
and no extra accesories.
My problem is this, I'm driving along ortigas extension for approximately 30min. The traffic was moderate and my speed was approx 20-30kph. I stopped for the pedestrian, then slowly moved 2-7meters. All of a sudden at idle, the engine starts to falter then kaput its dead. Started again for 3 times but was successful.
Started to moved the truck slowly to a parking space (buti na lang madaling itulak tong ganitong sasakyan!), when I checked the engine, I immediately noticed dripping gasoline under the carb. I'm an ECE grad, so unfortunately I don't no any of these things. All I did was remove the hose from the air filter, and check for broken fuel lines or anything odd. But I didn't see anything strange. Luckily, a mechanic passed by us and knew what exactly to do.
First, he removed the fuel filter, then drained the fuel from there. Then he started the truck, it started ok but the idle was not smooth. He rev the engine hard (>3000rpm???) for about 5-10min, then he let the engine idle. PRESTO!!!
everything's OK!!! I asked the mechanic whats was wrong and what caused it, he told me that the carb was overflowing with gas and that it needs to be drained, as for the reason he cannot explain it to me.
Now my question is, can somebody tell me the root cause of it? Can it happen again? During sundays, we bring this cab to cavite via SLEX, if it would happen again,
lets say in SLEX, I doubt if there would be a mechanic walking around.
I've tried googling around, and found out that I should clean and/or overhaul the carb. I'd like to here your comments. By the way my current engine is a new one
( Surplus, sariwa pa daw galing japan! ) bought it for 15k php, and its been running for almost 6 months. I'm only using this truck 2-3 times a week, mainit kc eh walang aircon.
Thanks in advance.
Thanks in advance.
Your carb is overflowing. Possible causes:
- defective float
- defective needle
- float tab needs adjustment
Of the above, you need to open up your carb to check on these.
Yes! Float problem
This happened to me last time my carb overflowed.
Take out your float. Shake it- listen for liquid inside. If yes, the float is cracked. Needs to be COMPLETELY DRIED OUT in the sun and then soldered at the crack. Not an easy task since the air inside expands when heated and then contacts when cooling, sucking in air through the crack you just soldered. :eek: So you should use a soldering gun- not a torch. And freeze the float before you solder it.
Not sure if there is a leak? Put it in the freezer for 5 minutes. Air will contract inside the float. Take it out and dunk it into a glass of hot water. Air will expand and escape from the crack. If no air bubbles come out, the float is good.;)
That means your needle valve or seat is leaking or most likely the little adjustment tab on the float needs to be bent to close the needle valve sooner. Easy fix
Good luck
Craig
Good luck
Craig
Thank you for the replies, but so far it did'nt happened again, even after the typhoon ondoy flood were in this truck is 120% submerged in flood water for 1-1/2 days and only had it running again after 1 month since the flood! ( I feel sorry for those cars with computer boxes though.) Anyway Its still running smoothly today except for the grinding noise every time I step on the clutch, i think its the release bearing I'm not sure but there's no problem on shifting gears.
About the float, if its cracked what could have caused it? could it be because of gasoline with E10(Ethanol 10%)? I remember, I carelessly filled my tank with that fuel.
More Power To You Guys!
Well, the water in the engine and the carb pretty much explains your problems. I'm surprised it runs at all after a month, since the seals in your engine and tranny usually will swell up and get damaged. Not to mention the bearings and other parts getting corrosion. Your throw-out bearing on your clutch is telling you that in it's own way ( :
I'd bet your float is not cracked, but was simply stuck from the corrosion (it is brass so when in contact with steel, will cause electrolysis and corrode at the hinge point).
In any case, I'd be saving up for the overhaul you will most likely need on both your engine and tranny after the water damage takes it's toll. You can try putting some additives in both the engine and tranny, change the oil in both once a month for a few months and see what happens. But when my head cracked and caused water to get in my honda engine, my mechanic told me straight up- overhaul it! He said don't wait for a catastophic failure because it will cost you alot more in parts and labor.
Better yet- replace (or oil it to make it quiet) the throw-out bearing and SELL your vehicle before anything more happens. You will make out better that way than throwing good money towards what will amount to the cost of a new engine and tranny. The only problem is, when you go to buy another vehicle you may be buying one that also got flood damage. I'm sure there are hundreds of those for sale as we speak.
As for the ethanol gas- I'm from Chicago, and they put that shit in the gas every summer since 1993, to prevent smog. Then they decided that it should be there all year round. ALL the gas has it- you got no choice. I heard stories about old school cars geting damaged since the ethanol burns hotter, but never caused me any problems.
Actually, ethanol EATS water (it's the same thing they use in that Prestone stuff used to remove water from your gas)- that's why it's not good to let it sit in your system for a long time without running it through because it will absorb water from the air. After a few months of the unused water-laden gas sits in your fuel system the problems will start.
Sorry to have to be the bearer of bad news.. good luck
Craig
Cebu
1 - 12 of 12 Posts
