1 - 1 of 1 Posts
ok, turns out the weber carb has a water choke.... , learn new things all the time, ive got to experiment with it some to try to figure out how it needs to be adjusted, but that seems to be the problem. took air cleaner off and manually closed choke butterflys and it cranked right up. also have a clutch issue- when depress pedal and get 1/2 to 3/4 way down it falls to floor, and when letting off it kicks back at u at the same spot. does this sound like an adjustment or bad clutch? 87 samurai 1.3 5sp weber
1 - 1 of 1 Posts
