Add year, make, model and location, also try and describe what happens when you try and start it, there are so many things that can keep it from starting that more specifics are needed to narrow it down. The sticky door is probably a separate issue.
My doors were starting to stick and the cause was the weather striping at the exterior base of the door glass was damaged, allowing water into the door causing corrosion of the locking mechanism. Check that exterior door strip and make sure its intact and pressing firmly against the glass.
