Hi I need help I just drove my car for 300km and it was fine. Then after that I can't put into any gear when the motor is running. I tried also to put it into 1st gear when the motor is not running and when I start it the car moved forward. I ask some mechanics, they say it might need new clutch or there is something leaking inside the transmission. My car is a 2003 suzuki aerio sx manual transmission.
Hydraulic clutch, right? Have you checked the fluid reservoir yet? :huh:
IF down (or dry)...yeah you have a leak. It can be either external or internal to the transmission bell-housing.
If fluid level is OK, then either the clutch master cyl, internal slave cyl or clutch proper is malfunctioning / broken. :(
I'm not quite sure what you hope to learn here, after having several Mechanic's already chime in.
