1 - 18 of 18 Posts
Can you hot-wire the transfer case somehow to force it into AWD and bypass the ECU altogether? How does the transfer case mechanically switch from FWD to AWD? This is a 09 SX4 Manual
This is not about the transfer case. AWD is applied at the coupler, which is at the rear differential. The coupler is an electrically activated clutch. OF course one can switch 12V directly to the coupler coil but I'm not sure of the time that the coil can survive with the full 12V. IN Auto 12V is applied in a duty cycle mode, that is, equivalent to reduced voltage based on conditions. In lock mode, I have not tested the actual duty cycle but if I were the designer, I would make it proportional to throttle. So...while your proposal has been also in my head at times, I would not risk abusing the coil.
Looking for the electrical diagram....will post later.
EDIT: everything here http://www.avigex.ca/sx4/AWDtrouble.pdf
NOtice there is a temperature sensor that limits the amount of AWD . This protection would be inactive if a direct 12V feed was installed....
Thank you for explaining that, I understand how it works much better now. I'm unable to use the AWD normally via the switch as there's problems with ESP that I'm not interested in fixing. At this point, I'm going to install a switch in my dash to give that coupler 12V directly and I'll just be mindful of when and how long I keep it on. I don't need AWD very often, only to power through snow or up a steep slippery hill etc. I own a parts SX4 so if something goes wrong I have a replacement coupler handy.
From your description of how the clutch engages, I understand that the voltage you apply to the coil effects how much pressure the clutch engages with. So if the car isn't moving or under load and there's a full disproportionate 12V on the coil, it will just heat things up and cause unnecessary wear and heat. If I'm understanding this right, when there is no voltage on the coil it should be completely disengaged? So the 4WD control module basically modulates how much voltage the clutch coil requires in relation to variables like the AWD switch position, load, speed, coupler temp, wheel slip, etc. I see how the 4WD module maximizes the life of the coupler.
Am I on the right track here?
yes and no.
Applying 12V directly to the coil will kill it in pretty short order due to over heating. I would expect it to last about 5 minutes. The controller varies the amount of current the coupler draws to control its "clamping" force. Its like a light dimmer, voltage stays the same, but the current gets varied.
Why not fix the ESP issue? what symptoms do you have? if you have a parts car then you have sensors, tone wheels and all the necessary bits to fix it.
I can't fathom why you say "i'm not interested in fixing it" when you seem willing to destroy a rather expensive AWD clutch pack by "hot wiring" it directly to a 12V supply rather than correcting the root cause of your lack of AWD.
yes and no.
This is an 09 SX4 AWD Manual. ESP doesn't work because several sensors are missing like the one in the center of the car right above the airbag control module. There's a instrument cluster from an automatic AWD in there that doesn't even have an ESP light and I'm sure that doesn't help anything. The parts car is an 07 SX4 and it turns out that the only difference I could find between model years is armrests and the gforce sensor for ESP. They're different sensors with different wiring unfortunately.
I'm not interested in buying the sensors needed, buying a instrument cluster specifically for a manual SX4 with AWD and ESP, then finding and paying somebody to program it. I'd rather program a raspberry pi to be a basic 4WD control module that watched speed and accelerator position via OBD, then regulate the amps to the coil accordingly. I'd rather spend time on an acceptable workaround then spending a bunch of money restoring the car to stock functionality.
Now I'm thinking of having 2 or 3 switches that each allow different amounts of current, then I could manually switch them depending on how much current I need. I don't need to use AWD heavily, what I have in mind is like flicking it on when starting on an icy hill. I realize that I probably sound like a loon. How many amps do you think this coil takes with no resistors?
Typically ~ 10 amps on a PM, which could be manager by controlled mosphets.. rather than a series of switches on dash..
... Philip
Get a new 4WD SW !!!
you obviously don't understand how the 4WD system works on these models, its fully electronically controlled and has varying torque split front to rear depending on wheel slip detected.
its not just a "switch"
Discussion Starter #12
Constructive comment. :rolleyes:
It's going to be a switch and current potentiometer pretty soon.
Yeah....I have searched the shop manual line by line in hope of finding the exact values of full current or resistance of the coil....to no avail.
Assuming (hypothesis) 6 amps current at 14 volts (actual running voltage), wanting to cut that in half means 3 amps, 7 volts, each at the coil and at the pot. This means 21 watt, 2.3 ohms (say at mid range)....a kind of heavy >5 ohms >42 rated watt pot for full range....hard to find, hot and expensive. That is why the PWM switch I suggested is almost certainly less expensive.....and dissipates barely no heat...may be 2 or 3 watt....because it is a ON-OFF switch, switching ON and OFF at around 15000 hz. IN fact your question made me realize the availability of those PWM controllers, so convenient and inexpensive. IN good old times, it would have been a time consuming, discrete parts search, printed circuit design or hard wiring in a spider fashion.....I'm going to order at least one just for fun....
work on about 10A at 12V, remembering to allow for 14.5 with vehicle running.
doing it with a mosfet will be a lot more complex, give better control but be smaller in size as the R d-s will be low meaning a smaller heatsink and no need for massive "watt wasters". You won't find a wire wound pot that will handle it, I have a couple of 10W ex WW2 radio ones and they are pretty massive beasts and made of rocking horse poop.
Go with the fet controller, way simpler and less heat issues.
Discussion Starter #17 (Edited)
Thanks for the help. I just bought 2 of the 20A ones.
https://www.ebay.com/itm/173215857744?ul_noapp=true
I also bought this so I can monitor the amps.
https://www.ebay.com/i/171927517543?chn=ps
I'll update this in a couple weeks with my results when the parts come from China and I get it installed.
the good thing with mosfets, running lower currents on higher powered devices causes no issues and they will run cooler. I would suggest fitting a decent spike suppression capacitor across the power input, car electrics are notoriously "noisy". You can use a decent radio "filter" designed for aftermarket amps or radios, they are cheap and will help protect the mosfet from damage from spikes caused by other stuff switching off and on like the AC and fans etc.
1 - 18 of 18 Posts
