1 - 11 of 11 Posts
I ordered a bunch of new parts for my 92 and then found out that it was in way worst shape then i thought so i ended up getting a 98. Just wondering if most of these parts are interchangeable between the 2 years, that way i can keep em for spares or try to sell them, please note that the 92 was not power steering but the 98 is, i have the following parts:
2x Rotors
Front Pads
Driver/Pass cv axles
Rear drums/Shoes/Hardware kit
2x U joint
I'm going to say yes, but I'm guessing. I've used those parts off a '96 Sunrunner on a '91 Tracker no problem.
2x Rotors
Front Pads
2x U joint
Just as long as one is not a Sport you should be ok BUT
I think you left out the most important info
2 or 4 doors?
You can check the P/N on one of the parts links.
2 or 4 doors?
Both are 2 doors
I would say yes as well, for the parts that you have listed.
Wasn't there a change in spline count somewhere along the way?
The other parts should be fine.
Transfer case output shaft spline changed from from 26 to 16 splines in 1996, I think.
I had the brilliant idea to cross check the parts on the autopartswarehouse website hehe, and from the website it tells me that the drums/shoes/hardware kit and passenger side cv axle are not the same......thats sucks
.. cross check the parts on the autopartswarehouse website hehe, and from the website it tells me that the drums/shoes/hardware kit and passenger side cv axle are not the same...
Keep in mind that many auto parts data-bases confuse non-sports with sports, and 2 doors with 4 doors. The brakes ARE different in both cases.
Use Suzuki databases.
I like this one... it is just a bit hard to use. suzuki-cat.ru
The front diff spline count changed 95~96 so the right axle (which goes directly into the diff) will be different.
1 - 11 of 11 Posts
