Hi all, i have a 2003 uk suzuki wagon r+special. Ive read a fault code and ive got to replace the camshaft sensor, does anyone know where this is located on the engine please? If its just a 1 bolt fix i can do myself if it requires no stripping of other parts. The general things online refer to the crankshaft sensor but i cant locate the camshaft sensor which is what i need to replace. Any advice would be great thanks in advance.
Not sure what engines in them, is it the M13 or G10 (1300cc or 1000cc).
If its the M13 does it have variable valve timing.
If not sure, post a pic.
Sorry Darrell was that a question regarding vvt im not with the car at present will have to check. Cheers
Thank you so much for the replies and pics, that was most helpful. I did locate and change the sensor but it made no difference im thinking egr valve? back to square one!
Darell thanks for the effort once again, most appreciated.
