Rock Auto do sell a range of metric bolts (in 5 packs) but only in 1.5 pitch and no comment on class. Bit of a bummer. However, as I said, check out Bolt Depot.
From Bolt Depot. Ph 866-337-9888
Cat #
11968 40mm 1.5 pitch 10.9 class $0.49 each
11969 45mm 1.5 pitch 10.9 class $0.56 each
15242 40mm 1.25 pitch 10.9 class $1.17 each
15243 45mm 1.25 pitch 10.9 class $1.32 each limited availability
They do have other lengths.
Somewhere on Bolt Depots site is a comparison between steel classes. Apparently a class 8.8 is similar to a 10.9 in strength BUT they only list class 8.8 in imperial settings but the 10.9 in metric. They do sell metric 8.8 also but you would have to find the chart and convert one set of readings.
I dear say the freight will be more than the bolts cost.
I can't help you much more than this.
Cat #
