Please put your car’s specs into your signature, and advise exactly what you are driving, engine, year, tranny, etc. Assuming that this is the 16v engine, the parts catalog indicates (at least for all US and EU market cars) that the timing belt part number is 12761 71C00.
By the way, hopefully you did not remove the center 17mm bolt when removing the crank pulley (unnecessary to do this, as the pulley will be removed with the 5 smaller bolts). If you did, make SURE that you retorque that bolt to 94 ft/lbs when replacing it (and if not, check the torque on that bolt while you’re there).
Yes, the timing belt is done to cylinder #4 firing. Maybe ‘wrong’ according to the FSM, but we’ve always lined it up before removing the existing belt.
