1 - 10 of 10 Posts
Hey y'all, I've had a squeaky belt issue lately, and I've actually had the problem solved in the past by getting a bolt matched up, but it has since fallen out. Guess it wasn't the right size after all. Does anyone know what size bolt I need from the pics below? The whole belt below where I've circled is wobbly to the touch. Not good.
Your arrow points to the a/c compressor mounting/adjusting bolt for tensioning the belt. There are 8mm and 10mm bolts for the compressor, but I don't know which is for your specific application - just for your info, the torque for the 8mm bolts is 21 ft/lbs and the torque for the 10mm bolts is 33 ft/lbs. When tensioning this belt, you are supposed to be able to press the belt inward (deflection) at 0.20-0.25 inch, when pushing on the upper portion of the belt between the compressor and crankshaft pulley.
Thanks for your reply. I'll try to match it up. I have another question, though. I've actually been considering removing the compressor entirely, since I never run the AC and for the sake of better mileage. Isn't it just another two bolts to get it off?
In general, you won't save anything of significance with regards to weight removal or eliminating the driving of the compressor IDLER pulley (horse power). :(
Actually, you may not even be ABLE to route a shorter belt due to new belt / engine interference issues that you might establish if the same belt runs other accessories.
I'm no expert on your particular set-up. Just food for thought.
I'm with Max on that removing the AC compressor wouldn't make a measurable difference in mileage or performance.
About the only reason I could think of to remove an AC system from a rig is to sell it or use it in a different TracKick. (Anyone in the southeast US want AC? No... not much use for AC there! ;) )
If the AC compressor is removed all you need is a shorter belt and moving one bolt on the power steering pump. This changes the pump from "fixed" to were it can be adjusted.
Note: The other bolt on the pump is "hidden" and reached THROUGH a hole in the pulley.
Discussion Starter · #6 ·
Thanks for the feedback, y'all. I'm going to just plan on replacing the bolt. I got the idea to remove the compressor after a buddy of mine removed his and almost doubled the mileage of his truck. If it truly won't make much of an impact, I don't see the point of removing it. I may just add a cold air intake instead, although I understand that their impact is a topic of debate when it comes to Trackers. Thanks again!
... remove the compressor ... and almost doubled the mileage of his truck. ...!
Something else was going on.
If not engaged, any AC compressor just free-wheels and doesn't take any more power to turn than an idler pulley.
--- Your truck, your money and your time. ---
"Double" the mileage would be hard to believe even if the compressor was always turning.
Discussion Starter · #8 ·
So I got a hold of the correct bolt, tried installing it.. and there's a piece of the old bolt lodged in there. Taking it to the shop tomorrow to get it drilled out. Fun times. Meanwhile, I've been riding around town with a loose belt making all sorts of noise.. Hopefully it ends tomorrow.
Good luck! Hopefully you will post back and advise that your problem has been solved...:)
Discussion Starter · #10 ·
She's all fixed now! :) My mechanic told me that there was one bolt holding my compressor on. He removed it, re-tapped the other two and replaced all the bolts. Amazingly, I didn't know that Trackers were SUPPOSED to be much more stable at 60+ mph. What an improvement! I won't be so anxious about highway driving anymore. When I first bought my Tracker last summer, all of the belts had just been replaced, and I guess whoever did the work didn't bolt everything back in correctly. Anyway, I'm relieved, and glad nothing worse ever came from that situation.
1 - 10 of 10 Posts
