Hey. Bought a new blower motor thinking that was the issue but installed new motor and didn’t work. I took the old motor and jumped it with a battery and started right up. I noticed that the two prong connector (power source) that connects to the motor has a wire loose and not connected. I can however hold wire in place and old motor works just fine. So my question is it possible to replace just that two prong connector? Thanks for reading and any advice !
FYI I know I found the bad connection one of the wires in the broken on the T connector like pictured above on the power supply. To save money I simply super glued the loose wire at the junction to hold in place and problem solved for a temporary fix. I’ll repost if replace the junction with the alternator junction you suggested if it works thanks again for the help!
