Just finished rear brakes on my 89 Sam.Bled the system and everything works fine.My question is this:There is what appears to be a proportioning valve on the frame rail on the passengers side about 12 inches in front of the fuel filter.Does this have to be bled also,and if so in what sequence.Thanks for any wisdom!
If you got all the air out of the rear and the pedal is firm you should be ok. If the brake light on the dash isn't on the valve should be centered and good to go.
