Welcome.
This is from the dealer service manual, however the pic is very small for it's location.
Sitting in the car it appears to be on the transmission, topside, just right of the master cyl. Mine is an auto, so I cannot take a pic of it and send it to you. Autos have them in a diff. location unfortunately. It is vertical.
Removal
1-disconnect neg. batt. cable.
2-disconnect vss coupler (I believe the elec. connector)
3-remove vss
Installation
1-check o-ring and vss surface for their flawlessness, appply oil to o-ring and driven gear and then install vss to trans.
Tightening torque 4.0 lb-ft
2-Connect vss coupler
3-Connect neg. cable at batt.
Hope this is helpful.
This applies to cars with the steering wheel on the left. Not clear where you are, and if the directions will apply as to where it is located.
