Greetings, i need to know the size of the center bearing that holds the center-right shaft from gearbox to right joint (see attachment).
I've a 1996 esteem (baleno), manual transmission, 1.6 liters
i'll appreciate size in milimeters as possible.
Thanks in advance.
Any auto parts store should be able to order the bearing for you, although if you are trying to go the cheap route and just get a bearing from a bearing dealer I have done that before and sometimes it is WAY cheaper.
But anyway...
Go to www . rockauto . com and then click on Suzuki, then 1996, then Esteem, then Drive Train, then Axle Shaft Bearing, then look though the list and find "CENTRIC Part # 41248002", there is a picture for it over on the right click on the picture and it has the measurements that you are looking for.
If the numbers are too small to read right click the picture and do "Save Image As" save it somewhere and then open it with whatever image viewer you have and then magnify it.
