· Registered
I was wondering if anyone knew the pin out to the wiring connector that leads to the backup camera mine has corroded and I can’t find a direct replacement so I will have to splice into it and try to make it work. I know someone on the forums has done this along time ago, but hoping for some good thanks.
· Registered
If you're just replacing the corroded plug, then wire to wire is all you need to do. If you plan on being able to unplug it, then just splice in a suitable plug and socket, doing one wire at a time. I have replaced several corroded molex style plugs with decent waterproof equivalent items, use good techniques as in sloler and glue filled heatshrink when joining wires.
· Registered
Sorry I should have been more clear. The camera itself corroded the connectors are fine. I need to splice into the harness that was leading to the camera, and then plug that back into the vehicle wiring harness.
· Registered
Discussion Starter · #4 ·
The aftermarket camera I have just has a red and black wire for power and a yellow rca for video with a trigger wire. The female plug coming from car is 6 pin plug with five of the six wire slots being populated.
